Capabilities for Template-based Invoice Customisation
Template-Based Invoice Customisation enables developers to create and customise invoice templates by controlling the appearance, layout, and behaviour of Forms, Parts, Lines, Fields, and Collections.
The following capabilities are available in Release 7.1.
Form Attributes
Color
The Color attribute allows you to define the font color for the entire form in display mode. All fields within the form inherit this color unless a specific color is defined at the field level.
Syntax
[Form: <Form Name>]
Color: <Color Name>
Where,
<Form Name> specifies the name of the Form in which the Color is defined.
<Color Name> specifies the name of the color to be applied to the Form.
Behaviour
  • Applies to all fields inside the Form.
  • Field-level Color takes priority over Form-level Color.
  • If not defined at either level, default system color is used.
Example
[Form: TSPLSMPLPrintCust]
Color: Blue
In the example, as Color is set to Blue, the Form TSPLSMPLPrintCust uses Blue as the font color in display mode. All fields within the Form inherit this color unless a specific color is defined at the field level.
Style
The Style attribute allows you to define the font style for the entire form in display mode. All fields within the form inherit this style unless a specific style is defined at the field level.
Syntax
[Form: <Form Name>]
Style: <Style Name>
Where,
<Form Name> specifies the name of the Form in which the Style is defined.
<Style Name> specifies the name of the style to be applied to the Form.
Behaviour
  • Field-level Style takes priority over Form-level Style.
  • If not defined at either level, default system style is used.
Example
Style : Normal Bold
In the example, as Style is set to Normal Bold, the Form TSPLSMPLPrintCust uses Normal Bold as the font style in display mode. All fields within the Form inherit this style unless a specific style is defined at the field level.
Print FG
The Print FG attribute allows you to define the font color for the entire form in print mode. All fields within the form inherit this color unless a specific print color is defined at the field level.
Syntax
[Form: <Form Name>]
Print FG : <Color Name>
Where,
<Form Name> specifies the name of the Form in which the Print FG is defined.
<Color Name> specifies the font color to be applied in print mode.
Behaviour
  • Applies in Print, Print Preview, PDF Export, and JPEG Export.
  • Field-level Print FG takes priority over Form-level Print FG.
  • If not defined, default print color is used.
Example
PrintFG : White
In the example, as Print FG is set to White, the Form TSPLSMPLPrintCust uses White as the font color in print mode. All fields within the Form inherit this color unless a specific Print FG value is defined at the field level.
Print Style
The Print Style attribute allows you to define the font style for the entire form in print mode. All fields within the form inherit this style unless a specific Print Style value is defined at the field level.
Syntax
[Form: <Form Name>]
Print Style : <Style Name>
Where,
<Form Name> specifies the name of the Form in which the Print Style is defined.
<Style Name> specifies the font style to be applied in print mode.
Behaviour
  • Field-level Print Style takes priority over Form-level Print Style.
  • If not defined, default print style is used.
Example
Print Style : Normal Bold
In the example, as Print Style is set to Normal Bold, the Form TSPLSMPLPrintCust uses Normal Bold as the font style in print mode. All fields within the Form inherit this style unless a specific Print Style value is defined at the field level.
Background Theme
The Background Theme attribute specifies the theme background color at Form level. The selected theme color is applied only to components where Apply Theme is set to Yes.
Syntax
Form : <Form Name>
Background Theme : <Color Name>
Where,
<Form Name> Specifies the name of the Form in which the attribute is defined.
<Color Name> Specifies the theme background color.
Behaviour
  • Does not apply automatically to the entire Form.
  • Applies only to Parts, Lines, or Fields where Apply Theme : Yes is specified.
  • Overrides existing Background color of that component.
  • Works in both display and print modes.
Example
[!Form: VPC TMPL ModernLayoutOne GST India]
Use : VPC TMPL Sales
Part : VPC TMPL MLOne TopSection, VPC TMPL MLOne InvGSTDtls GSTIndia
Page Break : VPC TMPL MLOne ClPageBreak, VPC TMPL MLOne OpPageBreak
Background Theme : Light Aqua
Option : VPC TMPL Bottom Footer Image : NOT $$InSampleMode
This example modifies the existing Form VPC TMPL ModernLayoutOne GST India and applies additional settings like Background Theme.
  • Background Theme : Light Aqua – Sets Light Aqua as the theme background color for the Form. This color is applied only to Parts, Lines, or Fields where Apply Theme : Yes is specified.
Watermark
The Watermark attribute is used to apply a Watermark definition to a Form.
A Watermark definition contains the required properties to display the watermark as Text or Image, such as content, size, color, alignment, and opacity.
When the Watermark attribute is defined at the Form level, the specified Watermark definition is used while rendering the Form.
Syntax
[Form : <Form Name>]
Watermark : <Watermark Name>
Where,
<Form Name> specifies the name of the Form in which the attribute is defined.
<Watermark Name> specifies the name of the Watermark definition to be applied.
Example
[!Form: VPC TMPL Imagewatermark]
Watermark : VPC TMPL Imagewatermark
In the example, as Watermark is defined, the Form VPC TMPL Imagewatermark applies the Watermark definition VPC TMPL Imagewatermark while rendering the Form.
Field Attributes
Sample Set As
The Sample Set As attribute is defined at the field level to assign a value to a field specifically for Sample Display mode.
This attribute is considered only when the report is opened using the Sample Display action and is ignored in all other modes such as Create, Alter, and Display.
In Sample Display mode, Sample Set As takes the highest priority and overrides both Info and Set As.
The effective priority order in Sample Display mode is:
Sample Set As → Info → Set As
Syntax
[Field : <Field Name>]
Sample Set As : <String>
Where,
<Field Name> specifies the name of the Field in which the attribute is defined.
<String> specifies the value to be displayed or printed in Sample Display mode.
Example
[Field: VPC TMPL BL BuyerSecondaryNo Arabic]
Use           : VPC TMPL Field
Set as        : @@VPCBuyer_SecondaryNo_BL_KSAeInv_English
Note          : @@VPCLocSecondaryNo
Sample Set As : $$Sprintf:@@VPCPHFormat:@@VPCBuyer_BL_SecNo_Label_KSAeInv_Arabic
In the example, as Sample Set As is defined, the field VPC TMPL BL BuyerSecondaryNo Arabic displays the formatted sample value returned by $$Sprintf:@@VPCPHFormat:@@VPCBuyer_BL_SecNo_Label_KSAeInv_Arabic when the report is opened in Sample Display mode. This value takes priority over the regular Set As value in that mode.
Label Field
The Label Field attribute is defined at the field level to mark a field as a label and control whether the label can be edited or hidden/disabled.
A label field is always a simple field and can also be used as a subfield of a compound field.
Syntax
Field: <Field Name>
Label Field: <Logical Value1>[ : <Logical Value2> : <Logical Value3>]
Where,
<Field Name> Specifies the name of the Field in which the attribute is defined.
<Logical Value1> Specifies whether the field is a label field. Supported values: Yes / No. Mandatory.
<Logical Value2> Specifies whether the label field is editable. Supported values: Yes / No.Optional.
<Logical Value3> Specifies whether the label field can be hidden/disabled. Supported values: Yes / No. Optional.
  • The second and third parameters are considered only when the first parameter is set to Yes.
  • If the first parameter is No, the remaining parameters are ignored.
  • The default value for all parameters is No.
  • Invalid values are treated as No.
Behaviour
  • A label field must be a simple field and can also be a subfield.
  • A line can contain multiple label fields, but only one can be hided. If multiple hided labels exist, only the first is considered.
  • Normal fields use label association at line level; subfields use label association at compound field level.
  • The attribute is ignored at compound field / parent field level.
  • A compound field can have at most one label field.
  • This capability is static and not intended for runtime dynamic changes.
Example
[Field: VPC TMPL Prompt]
Use : VPC TMPL DoubleClick
Width : 0%
Page Style : VPC TMPL Small
Case : Title Case Label
Label Field : Yes:No:No
In the example, as Label Field is set to Yes : No : No, the field VPC TMPL Prompt is marked as a label field. The label is not editable and cannot be hidden or disabled.
A data field is any field that is not marked as a label field, and a line can contain data fields with or without a label field.
Apply Text BG
The Apply Text BG attribute is defined at the field level to control whether the Change Field Background action applies the background color only to the text or to the entire field.
By default, the background color is applied to the entire field. When this attribute is set to Yes, the background color is applied only to the text portion of the field.
This attribute is useful in scenarios where highlighting only the text improves readability without affecting the full field width.
Syntax
Apply Text BG : <Logical Value>
Where,
<Field Name> specifies the name of the field in which the attribute is defined.
<Logical Value> specifies whether the background color should be applied only to the text or to the entire field. Supported values are Yes and No. The default value is No.
Example
[Field: VPC TMPL ApplyTextBG]
Apply Text BG : Yes
In the example, as Apply Text BG is set to Yes, the background color is applied only to the text portion of the field VPC TMPL ApplyTextBG, and not to the entire field width.
Note
The Note attribute is used to define helper text or a description for a field.
This attribute is useful when additional context needs to be shown for a field, such as in field property or customisation scenarios where users need to understand the purpose of the field.
The Note attribute is applicable only to simple fields and not to compound fields.
This capability is intended to be static. While expressions are supported, they are evaluated during the initial configuration phase and are not intended to change dynamically at runtime.
Syntax
Note : <String Expression>
Where,
<String Expression> specifies the helper text or description to be used for the field.
Example
[Field : Bill To]
Note : “Bill To Properties in Modern Templates”
In the example, as Note is defined, the field Bill To uses “Bill To Properties in Modern Templates” as its helper text or description.
Part Attribute
Next Page
The Next Page attribute is used to control whether a Part should start on the current page or move to the next page based on a logical condition.
At the Part level, this attribute determines whether the Part and its following content continue on the current page or begin from the next page.
This capability is useful when a complete Part must remain intact on a single page, such as headers, totals, grouped sections, or summary blocks.
The Next Page attribute is commonly used with the function $$DoesPartFit, which returns Yes if the Part fits on the current page, otherwise No.
Syntax
[Part : <Part Name>]
Next Page : <Logical Expression>
Where,
<Part Name> specifies the name of the Part in which the attribute is defined.
<Logical Expression> specifies the condition that determines whether the Part should begin on the next page. The expression must evaluate to Yes/No or True/False.
Example
[Part : Amount Chargeable]
Next Page : NOT $$DoesPartFit
In the example, the Part Amount Chargeable moves to the next page when it does not fit in the remaining space of the current page. This helps keep the complete Part together on a single page.
Auto Expand Width
Previously, when content inside a Part exceeded its declared width, the Part automatically expanded to accommodate the content, which could cause it to exceed the intended layout boundaries.
The Auto Expand Width attribute allows you to control how a Part behaves when its content is wider than the specified width.
When Auto Expand Width is set to No, the Part maintains its specified width even when the content is wider. When set to Yes (default), the Part expands to accommodate content wider than its declared width.
This attribute is useful when designing reports that require fixed-width layouts and consistent alignment.
Syntax
[Part: <Part Name>]
Width : <Width Specification>
Auto Expand Width : <Logical Value>
Where,
<Logical Value>  can be Yes or No and determines whether the Part should automatically expand when its content exceeds the specified width.
  • Yes (Default) – The Part expands beyond its declared width to accommodate wider content.
  • No – The Part maintains its declared width, and content is compressed horizontally to fit within the available space.
Example
[Part: MyFixedWidthPart]
Width : 60% Page
Auto Expand Width : No
In the above example, the Part width is restricted to 60% of the page width. Any content that exceeds this width is automatically scaled to fit within the defined boundary instead of expanding the Part.
Behavior
  • The attribute should be used along with the Width attribute.
  • The default value is Yes, ensuring backward compatibility with existing TDL definitions.
  • Existing Part definitions continue to behave as before unless Auto Expand Width is explicitly set to No.
Part/Line/Field Attribute
Apply Theme
The Apply Theme attribute to control whether the Background Theme defined at Form level should be applied to a Part, Line, or Field.
Syntax
Part/Line/Field : <Part/Line/Field Name>
Apply Theme : <Logical Value>
Where,
<Part/Line/Field Name> specifies the Part/Line/Field in which the attribute is defined.
<Logical Value> specifies whether the theme should be applied. Supported values: Yes / No. Default value is No.
Behaviour
  • Works only when Background Theme is defined at Form level.
  • Yes – Applies the Form’s Background Theme to the component.
  • No – Theme is not applied to the component.
  • If applied at Line level, all fields in that Line inherit the theme unless explicitly set to No.
  • If applied at Part level, contained Lines and Fields inherit the theme unless explicitly set to No.
  • In striped reports, themed lines use the Background Theme as stripe color.
  • Cursor and selection highlight colors remain unchanged.
  • Existing Background Theme takes priority over component-level Background.
Example
[Part: VPC TMPL MLOne eInvTitle]
Use : VPC TMPL eInv Title
Apply Theme : Yes
Width : 10% Page
Space Bottom : 0.25
In the example above Apply Theme is set to Yes which applies the Background Theme defined at the Form level to this Part. In this example, the Part “VPC TMPL MLOne eInvTitle” will use the Form’s theme background color for its background. Since the theme is enabled at Part level, the applied theme takes priority over any regular background color defined for this Part.
Line Attribute
Skip Common Border
The Skip Common Border attribute is defined at the line level to control whether the common border should be drawn when it passes through a component.
This attribute is useful in layouts where the common border overlaps or cuts through a component, resulting in cluttered or incorrect rendering.
Syntax
[Line : <Line Name>]
Skip Common Border : <Logical Value>
Where,
<Line Name> specifies the Line in which the attribute is defined.
<Logical Value> specifies whether the common border should be skipped. Supported values are Yes or No. The default value is No.
Behaviour
  • When set to Yes, the common border is not drawn for the line where the attribute is applied.
  • When set to No (default), the common border is drawn as usual.
  • The effect applies only when the common border intersects the component area.
Functions
$$InSampleMode
The $$InSampleMode function is used to determine whether a report is accessed in Sample Display or Sample Alter mode.
This function returns Yes only when the report is invoked through an action such as Sample Display or Sample Alter from a Menu, Button, or Key.
Internally, the platform evaluates the first non-auto report in the owner hierarchy and checks the action through which the report was invoked.
Syntax
$$InSampleMode
This function does not accept any arguments.
Returns Logical (Yes / No)
Example
Option : VPC TMPL ScrollFlow : NOT $$InSampleMode
In the example, the option VPC TMPL ScrollFlow is applied only when the report is not accessed in Sample Display or Sample Alter mode. When the report is opened in Sample mode, the condition evaluates to No.
$$IsLabelField
The $$IsLabelField function is used to check whether the current field in context is a label field.
This function is useful in field property and template customisation scenarios where the behavior or title needs to vary depending on whether the current field is a label field or a data field.
Syntax
$$IsLabelField
Example
VPC DefTitle : If $$IsLabelField Then $$LocaleString:”Set Title Style” Else $$LocaleString:”Set Field Properties”
In the example, the value of VPC DefTitle changes based on whether the current field is a label field. If the current field is a label field, the title is displayed as Set Title Style; otherwise, it is displayed as Set Field Properties.
Behaviour
  • The function evaluates the current Edit Field in the active report context.
  • If the current Edit Field is a label field, the function returns Yes; otherwise, it returns No.
  • When used from an auto-report or sub-form, the function evaluates the current Edit Field from the main owner report context.
  • If the function is used in a context where no report or current Edit Field is available, it returns Error.
