View Employee Vouchers in TallyPrime (Payroll)
You can view the Employee Vouchers from Payroll Reports or Statutory Reports under Display.
  1. Gateway of Tally > Display More Reports > Statutory Reports > Payroll Reports > Summary.
    Alternatively, press Alt+G (Go To) > type or select Payroll Statutory Summary > and press Enter.
  2. Press Enter on the required Pay Head Type.
  3. Press Enter on the required Pay Head.
  4. Press Enter on the required Employee Name.
  5. Press Alt+F5 (Detailed).
    The user can drill down to a corresponding Payroll/Payment Vouchers from the above report.
Ctrl+B (Basis of Values)
In Employee Vouchers, you can display Type of Voucher entries in reports. Press Ctrl+B (Basis of Values) > Type of Voucher entries > select All Voucher. Press Esc to view the default values.
Ctrl+H (Change View)
You can display the details of a report in different views with additional details or for a specific period. You can also view other reports related to the current report.
To view the Pay Head Employee Breakup, press Ctrl+H (Change View) > type or select Pay Head Employee Breakup > press Enter. Press Esc to view the default report.
Helpful?
