HomeTallyPrimePayrollPayroll MastersPayroll Statutory Pay Head Details
 PDF
View Payroll Statutory Pay Head Details in TallyPrime
To view the details of the Statutory Ledgers used for each Pay Head Type as shown in the Payroll Statutory Pay Head Details report,
  1. Gateway of Tally > Display More Reports > Payroll Reports > Statutory Reports > Summary.
    Or
    Gateway of Tally > Display More Reports > Statutory Reports > Payroll Reports > Summary.
    Alternatively, Alt+G (Go To) > type or select Payroll Statutory Summary > and press Enter.
  2. Press Enter on the required Pay Head Type.
    The above report provides the Pay Head level Computation breakup for the required Pay Head Type.
    You can drill down to the Employee Breakup of Pay Head reports for the respective Pay Heads.
Button Options in the Payroll Statutory Pay Head Details
  • Press Alt+F5 (Detailed/Condensed): To view the Pay Head details with respective values.
    The above report displays the Percentage as specified in the Pay head, A/c No. in case of Provident Fund, Pay Head wise calculation details are also displayed in the detailed view.
    Press Alt+F5 again to return to the normal mode.
  • Press F2 (Period): to change the selected period.
  • Press F3 (Company): to change the company.
  • Ctrl+J (Exception Reports): You can view the exceptions related to the data displayed in the current report, without closing the report.
    To view the TDS Variance for Payroll Statutory Pay Head Details, press Ctrl+J (Exception Reports) > type or select TDS Variance> and press Enter. Press Esc to view the default report.
Helpful?
