HomeTallyPrimeData ManagementImport DataParent Group is set as Cost Centre
Resolution
  1. Drill down from the exception.
  2. Press Enter twice.
  3. Press Alt+H (Multi Alter) to update the Parent Group.
  4. Select the appropriate Parent Group from the List of Employee Groups.
  5. Press Enter or Ctrl+A to save.
