Parent Group is Missing
Resolution
  1. Drill down from the exception. Press Enter twice.
  2. Select the exception and update the Parent Group.
    1. Press Multi-Alter. Alternatively, press Update Details.
    2. Select the Parent Group, for example Sundry Debtor, and save.
