HomeTallyPrimeData ManagementImport DataNumber of Decimal Places is more than 4
Resolution
  1. Drill down from the exception.
  2. Press Enter twice.
  3. Select the exception and update the number of decimal places.
    1. Press Alt+H (Multi Alter).
    2. Update the Number of decimal places to less than or equal to 4.
  4. Press Enter or Ctrl+A to save the master.
