Error Code 32
Cause:
This error may occur while opening TallyPrime in the following scenarios:
  1. TallyPrime data files (such as .tsf or .900/.1800 files) are locked by another process, such as third-party backup software or any other application that accesses the TallyPrime data files. At the same time, TallyPrime attempts to store the data to the database, but it fails.
  2. Since the Ransomware protection feature is enabled, the antivirus software blocks access to the TallyPrime data.
Resolution:
  1. Avoid accessing the TallyPrime database by copying or double-clicking the .tsf files.
  2. Schedule backups when no user is accessing the TallyPrime data.
  3. Exclude .tsf files from the Exclusion menu of backup tool.
  4. Add TallyPrime data files to the Exception list of the antivirus software’s Ransomware protection feature.
