Error Code 2147483650
Cause:
- Corrupted data files are present while accessing data over a network in a multi-user environment.
- Network fluctuation.
- Different types of network such as LAN and WIFI are used in the multi-user environment.
Resolution:
Take data backup and perform zero command rewrite.
Additionally, take the following measures to ensure this error does not occur again.
- Correct the fluctuations in the ping speed.
- In case there are any WIFI systems installed in the network, isolate that system to stop this problem from occurring repeatedly.
- Use same category of cable, preferably CAT 6 in all the client systems.
- Add TallyPrime data files to the Exception list of the antivirus software’s Ransomware protection feature.
