Keyboard Shortcut Keys
This topic lists the shortcut keys and other menu keys used in TallyPrime Developer.
Editor Keys
Short Cut Keys
Functionality
Up
To scroll the cursor up by a line
Down
To scroll the cursor down by a line
Left Arrow
To scroll the cursor left by a character
Right Arrow
To scroll the cursor right by a character
Home
To move the cursor to the beginning of the current line
End
To move the cursor to the end of the current line
PageUp
To move the cursor one page up at a time
PageDown
To move the cursor one page down at a time
Insert
To select the edit mode or override mode in editor window
Delete
To clear the next character from the cursor location or to clear the selected text
Esc
To come out of a dialog box, similar to the option ‘cancel’
Back Space
To delete one character back from the current location
Tab
To leave one tab space from the current location
Enter
To start a fresh line
Shift + Down
To select a line downwards from the cursor position
Shift + Up
To select a line upwards from the cursor position
Shift + Left Arrow
To select a character left of the cursor position
Shift + Right Arrow
To select a character to the right of the cursor position
Shift + Home
To select the text from the cursor location to the starting point of the line
Shift + End
To select the text from the cursor location to the ending point of the line
Shift + PageUp
To select one page up from the cursor location
Shift + PageDown
To select one page down from the cursor location
Shift + Insert
To paste the content from clipboard
Shift + Delete
To cut the selected text
Shift + Back Space
Shift + Tab
To move the cursor one tab back from the current location
Shift + Enter
Ctrl + <Mouse Click>
To copy contents from multiple locations or to paste the selected contents at multiple locations
Ctrl + Down
To scroll the page one line down at a time
Ctrl + Up
To scroll the page one line up at a time
Ctrl + Left Arrow
To move the cursor a word left
Ctrl + Right Arrow
To move the cursor a word right
Ctrl + Home
To move the cursor at the beginning of the file
Ctrl + End
To move the cursor at the end of the file
Ctrl + Insert
To copy the selection
Ctrl + Delete
To delete a word right from the cursor location
Ctrl + L
To cut the current line
Ctrl + T
Toggles current line with the line above it
Ctrl + Back Space
To delete one word back from the current location
Ctrl + ]
To point cursor to the next definition in a file
Ctrl + [
To point cursor to the previous definition in a file
Alt + Home
To point the cursor at the beginning of the line
Alt + End
To point the cursor to the end of the line
Alt + Back Space
Undo
Alt + Shift + Down
To move one line down during column selection
Alt + Shift + Up
To move one line up during column selection
Alt + Shift + Left Arrow
To move one character left during column selection
Alt + Shift + Right Arrow
To move one character right during column selection
Alt + Shift + Home
To extend the rectangular selection to the starting of the line
Alt + Shift + End
To extend the rectangular selection to the end of the line
Alt + Shift + PageUp
To select one page up from the current location during column selection
Alt + Shift + PageDown
To select one page down from the cursor location during column selection
Ctrl + Shift + [
To select one paragraph up
Ctrl + Shift + ]
To select one paragraph down
Ctrl + Shift + Left Arrow
To select a word from the left
Ctrl + Shift + Right Arrow
To select a word from the right
Ctrl + Shift + Home
To select the text from the cursor location to the beginning of the file
Ctrl + Shift + End
To select the text from the cursor position to end of the file
Ctrl + Shift + Delete
To delete the line right from the current location
Ctrl + Shift + Back Space
To delete the line left from the current location
Ctrl + Shift + L
To delete the current line
Ctrl + Shift + T
To copy the current line
Ctrl + Shift + ‘+’
To zoom in to the Editor Window
Ctrl + Shift + ‘-‘
To zoom out of the Editor Window
Ctrl + F2
To add bookmarks along required lines in the Editor
Shift + F2
To navigate to the Previous bookmark
F2
To navigate to the Next bookmark
Menu Keys
Short Cut Keys
Functionality
Del
Delete
F1
To get the Help Manual
F3
To find the next occurrence in the current file
F4
To find and replace the next search result
F7
To compile a file
F9
To build the current project
Shift + F3
To go back to the previous search result
Shift + F4
To find and replace the previous search result
Alt + P
To directly jump to any other File
Alt + 1
To hide Explorer window
Alt + 2
To hide Output window
Ctrl + N
To create a new TDL file
Ctrl + O
To open an existing TDL file
Ctrl + S
To save a file or a project
Ctrl + Z
Undo
Ctrl + Y
Redo
Ctrl + A
Select all
Ctrl + X
Cut
Ctrl + C
Copy
Ctrl + V
Paste
Ctrl + E
Execute OS Command
Ctrl + F
To find a text in the current file
Ctrl + D
To locate the given text in all the files
Ctrl + G
Move to a Line number
Ctrl + H
To find and replace a text with a new text
Ctrl + J
To directly Jump to any Definition
Ctrl + 1
To go to Project Explorer
Ctrl + 2
To go to Output Window
Ctrl + 3
To go to Edit Pane
Ctrl + 4
To go to Definition Explorer
Ctrl + 5
To go to Schema Explorer
Ctrl + 6
To go to Build Window
Ctrl + 7
To go to Search Window
Ctrl + 8
To go to Function Browser
Ctrl + 9
To go to Action Browser
Ctrl + F3
To move to the next search location
Ctrl + F7
To compile a project
Ctrl + Dot
To move to the original description from a reference or modifier
Ctrl + Plus
To expand the pointed definition
Ctrl + Minus
To collapse the pointed definition
Ctrl + /
To show all the references for the current description
Ctrl + PgUp
To jump to previous location
Ctrl + PgDn
To jump to subsequent location
Ctrl + Shift + N
To create a new project
Ctrl + Shift + O
To open an existing project
Ctrl + Shift + C
To comment one or more lines
Ctrl + Shift + U
To uncomment one or more commented lines
Ctrl + Shift + F3
To move to the previous search location
Ctrl + Shift+ /
To show all the modifiers for the current description
Ctrl + Alt + Q
To exit from Tally Developer
Ctrl + Alt + A
To open the Attribute References Search Dialog
Ctrl + Alt + D
To open the Definition References Search Dialog
Helpful?
