TallyPrime Developer
TallyPrime Developer is a comprehensive development environment designed for Tally Definition Language (TDL). Tally Definition Language or TDL is the development language of TallyPrime.
You need to buy a TallyPrime Developer license to use the complete features of the product.
Benefits of TallyPrime Developer
| Easy programming by syntax colouring, tagging and navigation of code, auto-completion, project management, and so on. |
| Ease of debugging, with error listing and diagnosis. |
| Build, compilation/validation/execution of code from within the product. |
| Authorization techniques for TCP ( Tally Compliant Product ) ensuring IP protection, controlled license usage, and minimized revenue leakage. |
| Easy distribution mechanism using licensing and subscription renewals. |
Easy customer serial number management. |
| Access to the complete Tally source code, as a reference. Ability to load multiple versions of the source code. |
| Instant references to TDL API’s such as schema, definition and attributes, functions, actions and so on. |
| Ability to extend multilingual support to the product, customisation, modules in localized languages with the powerful Dictionary Manager tool. |
| Tools that help to develop and test external application integration with TallyPrime (Tally connector). |
