What is the Use of Reference Tab in TallyPrime Developer | TallyHelp
The Reference Tab of Output window is used to display the result of the Reference Search. When the searched result is clicked, it will locate the referenced value.
All references found can be navigated in both directions, that is, next and previous references using the keys Ctrl+R and Ctrl+B , respectively.
