 PDF
TallyPrime Developer
TallyPrime Developer is a comprehensive development environment designed for Tally Definition Language (TDL). Tally Definition Language or TDL is the development language of TallyPrime.
You need to buy a TallyPrime Developer license to use the complete features of the product.
Benefits of TallyPrime Developer
Easy programming by syntax colouring, tagging and navigation of code, auto-completion, project management, and so on.
Ease of debugging, with error listing and diagnosis.
Build, compilation/validation/execution of code from within the product.
Authorization techniques for TCP ( Tally Compliant Product ) ensuring IP protection, controlled license usage, and minimized revenue leakage.
Easy distribution mechanism using licensing and subscription renewals.
Easy customer serial number management.
Access to the complete Tally source code, as a reference. Ability to load multiple versions of the source code.
Instant references to TDL API’s such as schema, definition and attributes, functions, actions and so on.
Ability to extend multilingual support to the product, customisation, modules in localized languages with the powerful Dictionary Manager tool.
Tools that help to develop and test external application integration with TallyPrime (Tally connector).
Helpful?
