Explore Categories
 PDF
Dictionary Manager Tool in Tally Prime Developer
Dictionary Manager helps to translate the default product strings as well as user TDL strings into any language. The application allows translation of strings used in the default product, and customisation into the selected language. It creates a final dictionary file .DCT , to distribute it along with the product, and the TCP.
By providing authentication details you can secure the dictionary files. The process of securing the .DCT file is similar to TCP compilation.
You can launch the Dictionary Manager from the Tools menu of TallyPrime Developer.
 Note:  Refer to the section  Dictionary Manager for the detailed explanation of dictionary manager functionality.
Helpful?
