Getting List of Companies
XML request for getting the list of online companies is sent to the URL (Test/Live).
HTTP Headers
SOURCE : <Partner Source Name>
TARGET : TNS
CONTENT-TYPE: text/xml;charset=utf-16
XML Message
<ENVELOPE>
<HEADER>
<VERSION>1</VERSION>
<REQVERSION>1</REQVERSION>
<TALLYREQUEST>Export</TALLYREQUEST>
<TYPE>DATA</TYPE>
<ID>TPGETCOMPANIES</ID>
<SESSIONID>{ Session ID} </SESSIONID>
<TOKEN >{Incremental Token Number} </TOKEN>
</HEADER>
<BODY>
<DESC>
<STATICVARIABLES>
<SVINCLUDE>Connected</SVINCLUDE>
</STATICVARIABLES>
</DESC>
</BODY>
</ENVELOPE>
In the XML Request,
- {Session ID} is obtained after the user logs in to the authentication library, when online.
- Apart from the <SESSIONID>, TNS expects one more tag <TOKEN>. This is an incremented number for every request made by the application. For example, if in the first request, the <TOKEN> value is then the subsequent request would have the value incremented by i.e., and so on.
- <SVINCLUDE> is the variable used to filter and return only the online or connected companies.
Note: In developer mode (testing phase), redirect the initial request to the URL https://dev1.tallyenterprise.com, and in live mode redirect the initial request to the URL to https://tallynet.tallyenterprise.com
XML response with the list of online/connected companies.
XML Message
<ENVELOPE>
<HEADER>
<VERSION>{XML Version}</VERSION>
<STATUS>{0 or 1}</STATUS>
</HEADER>
<BODY>
<DATA>
<COMPANY.LIST>
<REMOTECOMPANY>
<COMPANYCONNECTNAME>
{Tally Remote Company Name1}
</COMPANYCONNECTNAME>
<ACCOUNTINTERNALID> {Account ID} </ACCOUNTINTERNALID>
<TRBURL> {URL} </TRBURL>
<CONNECTED> {0 or 1} </CONNECTED>
</REMOTECOMPANY>
<REMOTECOMPANY>
{Tally Remote Company Name2}
</REMOTECOMPANY>
</COMPANY.LIST>
</DATA>
</BODY>
</ENVELOPE>
In the XML response, <REMOTECOMPANY> tag repeats for every company accessible to the user.
