HomeDeveloper ReferenceTally Authentication LibraryAuthentication Library - Troubleshooting
Authentication Library – Troubleshooting
This topic lists common error message and their corresponding solutions.
Error or Fault Response with Error Code
The error or fault responses from Tally.NET Server are received in the following XML format:
<ENVELOPE>
<HEADER>
<VERSION>1</VERSION>
<STATUS>1</STATUS>
</HEADER>
<BODY>
<DATA>
<STATUS>
<CODE>15004</CODE>
<MSG.LIST>
<MSG>Invalid Request</MSG>
</MSG.LIST>
</STATUS>
</DATA>
</BODY>
</ENVELOPE>
List of Error Codes
Error Code
Error
Description
Invalid Tally.NET ID or Password.
Provide correct username and password in TPAuthenticateUser request.
2
15002
Invalid request.
Tally.NET Server is not able to identify the request.
Contact Tally Solutions Pvt. Ltd. with request XML.
3
15005
Invalid request.
Tally.NET Server is not able to process the request. This could be because of the request format mismatch.
Tally.NET Server expects requests to be in UTF-16 (Unicode) and Little Endian format.
Request cannot be served, please try later.
Tally.NET Server internal error.
This happens only when the server is not available at the time.
This issue does not occur in a live scenario.
5
16010
Tally.NET Server internal communication error.
This happens only when the authentication server is busy. Retrial is suggested.
6
16027
Invalid Session.
Token is not incremented properly for each request, or the SessionID sent in the TPAuthenticateUser is invalid.
7
16032
Company is currently not connected with Tally.NET Server.
The expected company from TallyPrime is not connected to Tally.NET Server. Connect valid companies from TallyPrime.
8
16063
You have exceeded the Tally.NET user session limit.
Logout from the existing Tally.NET user session.
IDE Errors
If the editor—eclipse, xcode—displays an error, clean the project.
Helpful?
