Syntax Coloring for Attributes and Keywords
Attributes and Keywords within every definition are coloured in blue.
In the above code snippet, all the attributes within definitions are indicated in blue colour.
If the value of the attribute is a definition reference, keyword or string, then the values are marked in mulberry colour. The system formula names under the system definition are coloured in black and are in bold. The colour of keywords that is, fixed attribute values, data types and operators are changed to process blue.
In the above code snippet, the attribute values that are Keywords or strings are indicated in mulberry colour.
