Incremental Search
Incremental Search is an in-line progressive search that helps to find matched text as you type.
To search for a string incrementally
  • Go to Search > Incremental Search . The Incremental Search box is displayed below the Output window.
  • Enter the text or expression to be searched in the Incremental Search box. The search is initiated from the line where the cursor is placed in the Editor window.
  • Click Find Next from the Search menu or press F3 to find the next result for the current search.
  • Click Find Prev from the Search menu or press Shift + F3 to find the previous result for the current search.
Helpful?
