UDFs Changed to Internal Storages
A few internal UDFs are moved to internal storages to maintain coding standards and to sanitise code, to provide appropriate names to respective storages.
Impact
The name of the few UDFs is changed when they moved as storage. Hence, if these UDFs are referred to anywhere within customisation to fetch the value, all those method names to be renamed. However, if these are used as storage within the customisation, the same to be retained under [System:  UDF] definition. Hence no changes would be required in those customisations.
Object-wise List
Below is the Object-wise list of UDFs that are changed to internal storages.
Company
UDF name until Release 2.1
Storage name from Release 3.0
UDF_EconomicActivityCode
CMPEcoActivityCode
UDF_CMPAuthorisedPersonName
CMPAuthPersnName
UDF_CMPAuthorisedPersonDesignation
CMPAuthPersnDesgnation
UDF_CMPAuthorisedPlace
CMPAuthorisedPlace
UDF_CMPCircleWard
CMPCircleWard
UDF_CMPImportExportCode
CMPImportExportCode
UDF_CMPCircleSector
CMPCircleSector
UDF_CMPTaxAuthorisedPerson
CMPTaxAuthPerson
UDF_CMPCircleDivision
CMPCircleDivision
UDF_VATDistrictName
VATDistrictName
CENVATDuty Allocations
UDF_CENVATBillName
CENVATBillName
UDF_PartyLedger
PartyLedger
UDF_TaxUnit
TaxUnitName
UDF_PartyLedgerMstId
PartyLedgerMstId
tempTaxAmount
TaxAmount
UDF_StockItemName
StockItemName
UDF_BilledQuantity
BilledQuantity
UDF_TaxRate
TaxRate
UDF_StockItemMstId
StockItemMstId
UDF_AssessableAmount
AssessableAmount
UDF_TaxAmount
TaxAmount
VATStatutoryDetails
UDF_VATWCDeductionAmount
VATWCDeductAmt
UDF_WCTotalDeductionAmount
Voucher
UDF_VATDistrictName
VATDistrictName
UDFVATForm49No
VATForm49No
UDFVATCategoryType
VATCategoryType
UDFVATDocumentType
VATDocType
UDFVATWayBillNo
VATWayBillNo
UDFVATWayBillQty
VATWayBillQty
UDF_VATDocumentType
VchVATDocumentType
UDF_RefundOrderNo
RefundOrderNo
UDF_VATPurposeCode
VATPurposeCode
UDF_VATWCDescription
VATWCDesc
UDF_VATBank
VATBank
UDF_VATBranch
VATBranch
UDF_VATDDChequeNo
VATDraftChequeNo
UDF_VATIssueBank
VATIssueBankName
UDF_VATPaymentMode
VATModeofPayment
UDFDepotName
DepotName
UDFEICheckPost
VATCheckPost
UDF_VATDescription
VATDescription
UDF_VATBriefDescription
VATBriefDesc
UDF_CMPTypeofDevice
CMPTypeofDevice
UDF_VATExportEntryNo
VATExportEntryNumber
UDFVATCSTE1SeriesNo
VATCSTE1SeriesNumber
UDFVATCSTE1SerialNo
VATCSTE1SerialNumber
UDF_CMPDeviceNo
CMPDeviceNo
UDF_VATExemptCertificateNo
VATExemptCertifiNo
UDF_BuyerPINNumber
BuyerPINNo
UDF_ConsigneePINNumber
ConsigneePINNo
UDF_VATWCDeductionPerc
VATWCDeductionPerc
UDF_IsVATResTaxInvoice
IsVATResTaxInv
UDF_VATDepositDate
VchVATDepositDate
UDFReferenceDate
VchReferenceDate
UDFEIDespDate
EIDespDate
UDFVATCSTE1SeriesDate
VATCSTE1SeriesDate
UDF_VATWCDeductionAmt
VATWCDeductionAmt
UDF_VATWCOtherDeductionAmt
VATWCOtherDeductAmt
Voucher > All Ledger Entries
UDF_CENVATDutyAllocations
VATWCDeductAmt
UDF_VATWCDeductionRate
VATWCDeductRate
Voucher > All Ledger Entries > CENVATDuty Allocations
UDF_CENVATDutyItemAllocation
Voucher > All Inventory Entries
VATWCDeductAmt
Helpful?
