 PDF
Button Framework in TDL
On this page, you will get all the information about the button related enhancements are done in TallyPrime Release 1.0.
Formatting Attributes
Color
The attribute Color is used to specify the foreground color of the title of the button when the button is in an active state.
Syntax
[Key/Button: <Key/Button Name>]
Color : <Required color>
Example
[Button: TSPLsalesExecutive]
Color : Black
KeyColor
The attribute KeyColor is used to specify the foreground color of the Key of the button when the button is in an active state.
Syntax
KeyColor: <Required color>
Example
KeyColor : Blue
InactiveColor
The attribute InactiveColor is used to specify the color of the Key and Title of the button when the button is in an inactive state.
Syntax
[Key/Button : <Key/Button Name>]
InactiveColor : <Required color>
Example
InactiveColor : Grey
Background
The attribute Background is used to specify the color of the button when the button is in an inactive state.
Syntax
Background : <Required color>
Example
Background : Grey
Style
The attribute Style is used to specify the font-style of the title of the button.
Syntax
Style: <Required font-style>
Example
Style : Small
KeyStyle
The attribute KeyStyle is used to specify the font-style of the key of the button.
Syntax
KeyStyle: <Required font-style>
Example
KeyStyle : Small Bold
Border
The attribute Border is used to specify the Border for the button.
Syntax
Border: <Required border>
Example
Height
The attribute Height is used to specify the height for the button. This attribute is not applicable for Top and Bottom Toolbar buttons.
Syntax
Height : <Required Height>
Example
Height : 5% Screen
Width
The attribute Width is used to specify the width for the button. This attribute is not applicable to the Right Toolbar buttons.
Syntax
Width : <Required Width>
Example
Width : 10% Screen
FocusBG
The attribute FocusBG is used to specify the background color of the button when it is focused. This is applicable for Inline Buttons only.
Syntax
FocusBG : <Required Color>
Example
FocusBG : Deep Grey
Space Left
The attribute Space Left is used to specify the space to be kept on the left side of the button.
Syntax
Space Left : <Required Space>
Example
Space Left : 5% Screen
Space Right
The attribute Space Right is used to specify the space to be kept on the right side of the button.
Syntax
Space Right : <Required Space>
Example
Space Right : 5% Screen
Horizontal Align
The attribute Horizontal Align is used to align the contents of the button horizontally.
Syntax
Horizontal Align : < Left / Centre / Right>
Example
Horizontal Align : Left
Vertical Align
The attribute Vertical Align is used to align the contents of the button vertically.
Syntax
Vertical Align : < Top / Centre/ Bottom >
Example
Vertical Align : Centre
Key Vertical Align
The attribute Key Vertical Align is used to align the Key of the button vertically.
Syntax
Key Vertical Align : < Top / Centre/ Bottom >
Example
Skip Forward
The attribute Skip Forward is used to Skip the button and move forward. If the key ‘Back Space’ is executed from the consecutive button/field then the focus moves back to this button.
Syntax
Skip Forward : < Logical Value>
Example
Skip Forward : Yes
This attribute Image is used to specify the image from the specified resource. The Button will support the image formats like Jpeg, Bitmap, Icon, and Cursor. The resource type in the resource definition can be Bmap, Jpeg, Icon, Cursor.
Syntax
Image : < Logical Value>
Example
[Button: Show Image]
Key     : Alt + S
Action  : Display : Stock Item Image
Image   : Show Image
[Resource: Show Image]
Source : d:\tp\Button\StockItem.jpeg
Resource Type : Jpeg
Line
The attribute Line is used to specify the number of lines for the button. By default, any button has a maximum of 1 line on the display screen. In case more than one line is required to accommodate a content then this attribute is used.
Syntax
Line : < Value>
Example
[Button: TSPLsalesExecutiveSummary]
Title : “Sales Executive wise Summary”
Lines : 2
Inline Button
The buttons that can be placed inside the report are called Inline Buttons. These are declared inside the ‘Part’ definition, with the attribute ‘Button’.
Syntax
[Part : <Part Name>]
Button : <Button Name/ Names>
Example
[Part: TSPLsalesExecutiveSummary]
Button : TSPLsalesExecutive
Horizontal Align
The attribute Horizontal Align specifies the horizontal alignment of the buttons or parts of this part.
Syntax
Horizontal Align : <Left / Center / Right>
Vertical Align
The attribute Vertical Align specifies the vertical alignment of the button.
Syntax
Vertical Alignment : <Top / Center / Bottom>
Modifier Key
The attribute Modifier key helps in merging buttons that perform similar kinds of actions. The keys Alt, Ctrl are used to differentiate with the original key and provides the capability to execute another action. If the user presses any modifier key (Ctrl, Alt), the button gets regenerated to show the corresponding Key and Title.
Syntax
Modified Key : <Button/Key Name>
Example
[Button: TSPLFortnight]
Title : $$LocaleString:”Fortnightly”
Key : F6
Action : Set: SVPeriodicity :”Fortnight”
Modifier Keys : TSPLMonthly, TSPLQuaterly
[Button: TSPLMonthly]
Title : $$LocaleString:”Monthly”
Key : Alt + F6
Action : Set : SVPeriodicity :”Month”
[Button: TSPLQuaterly]
Title : $$LocaleString:”Quaterly”
Key : Ctrl + F6
Action : Set: SVPeriodicity :”3 Month”
Popup Menu
The action Popup Menu prompts a specified menu as a drop down/pop up menu from the Top Toolbar button.
Syntax
Action : Popup Menu : <Name of the Menu>
Example
[Button: TSPL Top Toolbar]
Action : Popup Menu : TSPL Sales Analysis
[Menu: TSPL Sales Analysis]
Title : “Sales Analysis”
Item : @@locSalesAnalysis : Display : SalesAnalysis Report
The menu items can have short cut keys, as mentioned below.
Key : @@ locSalesAnalysis : TSPL SalesAnalysis
[Key: TSPL SalesAnalysis]
Key    : Alt + S
Action : Display : SalesAnalysis Report
Further, Popup menus can have sub popup menus. Such Popup menus are called as Nested Popup Menu.
Example
Item : @@locSalesExecutiveAnalysis : Popup Menu : SalesExecutiveAnalysis
[Menu: SalesExecutiveAnalysis]
Title : “Sales Executive wise Sales Analysis”
Item : @@locSalesExecWiseSales : Display : SalesExecWise Sales Report
Item : @@locSalesOurstanding : Display : SalesOutstanding Report
Helpful?
