 PDF
System Related Functions
$$ExcelInfo
This function is used to get the Excel ‘version’ and to check whether ‘XLSX’ format is supported.
Syntax
$$ExcelInfo : <Keyword>
Where,
<Keyword> can be IsXLSXSupported or Version. The keyword IsXLSXSupported returns TRUE, if the format “xlsx” is supported, while Version returns the Excel version number.
Example
Set As : $$ExcelInfo:IsXLSXSupported
$$IsInternetActive
$$IsInternetActive is a function which helps to determine if the Internet is currently active. It returns TRUE if the Internet is accessible, else returns FALSE. It can be used to perform conditional operations, i.e., based on the Internet Connectivity, certain actions can be triggered.
This function checks if the internet is active, such that the operations pertaining to connecting to web pages, emailing, uploading files to FTP, etc., can be performed.
Syntax
$$IsInternetActive
Example
[Function : EmailifConnected]
00 : IF : $$IsInternetActive
;; Function called to Email O/s Stmts
10 : Call : Email Outstanding Statements
20 : ENDIF
In this example, the Outstanding Statements are E-Mailed, if Internet connection is present.
SysInfo
Use the function SysInfo to retrieve system-related information, like system date, operating system version, and so on. $$SysInfo accepts one parameter at a time, out of the 19 explained below.
Syntax
$$SysInfo : <Parameter>
where <parameter> is one of the values explained in the table below.
No.
Parameter
Description
Example
ApplicationPath
The folder path where the current copy of Tally is running.
C:/TallyPrime
2
CurrentPath
The data path configured in tally.ini, residing in the application path.
C:/TallyPrime/Data
3
SystemDate
The system date.
27-May-2017
SystemTime
The system time.
18:27
5
SystemTimeHMS
The system time in hh:mm:ss format.
18:27:36
6
SystemName
The system name.
TallyClient2
7
IsWindows
Checks whether the system has Microsoft Windows operating system.
Yes
8
WindowsVersion
The Microsoft Windows version with the build number.
6.2 (9200)
9
WindowsUser
The name of the Windows user who has logged in.
geetha.ram
10
IPAddress
The IP Address of the system.
192.168.1.17
11
MACAddress
The Media Access Control Address of the network adapter in the system.
0720fhac027a
12
RunningIPV4Addr
The currently running Internet Protocol Version 4 address.
192.168.1.17
13
RunningIPV6Addr
The currently running Internet Protocol Version 6 address.
2001:db8:85a3:8d3:1319:8a2e:370:7348
14
IsOSx64
Checks whether the operating system is 64-bit.
Yes
15
IsAdmin
Checks whether the operating system is running in Admin mode.
No
16
TallyinAdminMode
Checks whether TallyPrime is running in Admin mode.
No
17
UACStatus
Checks whether the User Account Control is enabled.
Yes
18
SystemProxySettings
The proxy settings in the system.
192.168.1.17:8000
19
ModuleName
The folder path and file name of the current application.
C:/TallyPrime/tally.exe
The function SysInfo is enhanced to get the file name of the current application with the folder path.
Example
$$SysInfo:ModuleName
If the application path is C:\TallyPrime , it returns C:\TallyPrime\tally.exe .
$$MakeFTPName
Function $$MakeFTPName is used for creating the file transfer protocol, based on specifications.
Syntax
$$MakeFTPName : <FtpServer>: <FtpUser>: <FtpPassword>: <FtpPath>
Where,
<FtpServer>is the FTP server name.
<FtpUser>is the FTP user name.
<FtpPassword>is the FTP password.
<FtpPath>is the full path of the folder on the FTP server.
Example
$$MakeFTPName:”ftp://ftp.microsoft.com”:””:””:”dbook.xml”
$$MakeHTTPName
Function $$MakeHTTPName is used for creating the HyperText Transfer Protocol for the specified security features.
Syntax
$$MakeHTTPName : <HttpUrl>: <HttpIsSecure>: <HttpUserName>: <HttpPassword>: <CompanyName>
Where,
<HttpUrl>is the HTTP URL name.
<HttpIsSecure>is a logical attribute which checks whether the HTTP is secure or not.
<HttpUserName>is the HTTP user name.
<HttpPassword>is the HTTP password.
<CompanyName>is the name of the Company.
Example
$$MakeHTTPName:”https://www.abc.com”:Yes:”guestuser”:”pswd99″:”ABC Company Ltd”
$$ MakeMailName
Function $$MakeMailName is used to construct the URL. The mail is sent to specified mail addresses using the given server.
Syntax
$$MakeMailName :<ToAddress>:<SMTP Sever name>:<From Address>:<CC Address>:<Subje c t>:<Username>:<Password>:<Use SSL flag>
Where,
<ToAddress>is the e-mail id of the receiver.
<SMTP Server Name>is the name of the server from which the mail is sent.
<From Address>is the send e r’s e-mail id.
<CC Address>is the email-id where the copy of the mail is to be sent.
<Subject>is the subject of the mail.
<User Name>is the user id on the secured server.
<Password>is the password for the user id on the secured server.
<Use SSL Flag>can be TRUE / FALSE OR YES / NO. If the Use SSL flag is set to TRUE, then the Username and Password must be specified, i.e., they can’t be empty.
Example
$$MakeMailName:”xyz@xyz.com”:”smtp.gmail.com”:”abc”+”<“+”abc@abc.com”+”>”:”Your outstanding payment”:abc@gmail.com:abc123:True
Helpful?
