Explore Categories
 PDF
Install TallyPrime Developer
You can install TallyPrime Developer from the downloads page on the Tally Website.
TallyPrime Developer is compatible with Windows XP SP2 or higher versions of the Windows operating system (including Windows 10).
To install TallyPrime Developer
  1. Double-click the setup.exe to open the TallyPrime Developer installer.
  2. Select the required folder path in the Application path if you do not want to install TallyPrime Developer at the location selected by default.
  3. Cilick Install, to install the latest version of the TallyPrime Developer.
Helpful?
