This topic lists the different FAQs on TallyPrime Developer. It covers different areas in TallyPrime Developer and the responses to each of the TallyPrime Developer questions.
Every font color/colour and style has its significance while writing code, hence we do not allow changing them in TallyPrime Developer.
Tally Search option is used to search for a string of text. It searches the string with/without spaces between them, prefixed or suffixed with other characters. But if Normal Search option is selected then it will search for the exact matching strings only.
