Explore Categories
 PDF
Line Related Attributes
Access Names
This attribute is used to identify the line by using unique access name.
Syntax
Access Name : Access Name Formula
Where,
< Access Name Formula > can be a formula which evaluates to a string.
Example:
[Line : Sample Line]
Field       : Sample Fld1, Sample Fld2
Access Name : “Repeated Line” + $$String:$$Line
Selectable
At Line level, the attribute Selectable indicates whether the line (or lines within the line) is selectable or not. The default value of attribute ‘Selectable’ for repeated lines is ‘YES’, and for non-repeated lines is ‘NO’. The value is also inherited from Parent Part/Line, and the same can be overridden at Line level.
Syntax
Selectable : <Logical Formula>
where,
<Logical Formula> must return the value as Yes or No
Explode
The attribute ‘Explode’ refers to an attribute of the line, which is used to take the current data from the Line Object. A Part is displayed after the process of explosion is complete.
Syntax
Explode : <Part Name> : <Logical Condition>
Where,
< Part Name > is the name of the Part which displays additional information about the Line object.
< Condition > if True, will result in an explosion.
Next Page
The Next Page attribute specifies the cut off line that gets printed in the subsequent page. It accepts a logical formula as its parameter.
Syntax
[Line : <Line Name>]
Next Page : <Logical Formula>
Example
[Line : DSP Vch Explosion]
Next Page : (($$LineNumber = $$LastLineNumber) AND $$IsLastOfSet)
Preprinted/PrePrinted Border
The Attribute Preprinted or Preprinted Border can be specified at Part, Line and Field Definitions. These attributes work in conjunction with ‘preprinted/ plain’ button in the Print Configuration screen. When the Preprinted attribute is set to YES, the contents of the current Part, Line or Field will be left blank assuming the same to be pre-printed. When the ‘Preprinted Border’ attribute is set to YES, the borders used in the current Part, Line or Field will be assumed to be pre-printed.
Syntax
Preprinted : <Logical Value>
Example :
[Line : Company Name]
Preprinted : Yes
Helpful?
