HomeTallyPrimeData ManagementImport DataConversion Factor of Compound Unit is Invalid
Resolution
  1. Drill down from the exception.
  2. Press Enter twice.
  3. Select the exception and update the conversion factor of the compound unit.
    1. Press Alt+H (Multi Alter).
    2. Update the conversion factor.
  4. Press Ctrl+A to save the master.
