Job Management
This function allows the user to describe the available job vacancies and provide preferential parameters for seeking employable candidates.
The prospective employer needs to fill in the required details about the jobs available at the business location, specify the preferences for locating candidates for each job requirement and publish the job on the website.
Candidates who had enrolled with the job portal will in turn check the website and apply for the jobs published or the employer needs to search for candidates and consider for recruitment. By default, the Job Management section contains the Default job.
Create and Publish Jobs
To create a job and publish it follow the steps shown:
From the Control Centre select J: Jobs & Recruitment
The List of Job(s) screen appears as shown:
The Create Job screen appears as shown.
The completed Job Details screen appears as shown:
The List of Job(s) screen appears displaying the newly created job as shown:
Note: The Statistics for jobs are displayed in the bottom most part of the screen.
Number of Job(s) displays the number of jobs available.
Published displays the number of jobs published.
Expired displays the number of jobs have that have fulfilled the requirement.
Fulfilled displays the number of jobs that met the requirement.
Not Fullfilled displays the number of jobs that did not meet the requirement.
Not Published displays the number of jobs that were not published.
Job Alteration: To alter jobs of any status in order to modify the parameters set in the job creation screen, select the required job from the List of Job(s) and press Enter. The Job Alteration screen similar to Create Job screen appears. Make the required changes and Accept to save the screen.
The user can perform the following tasks in the List of Job(s) screen.
F1: Detailed
To view the List of Job(s) in detail, from the List of Job(s) screen:
The detailed view of List of Job(s) screen appears as shown:
Note: This button toggles between Condensed/Detailed.
F2: Period
This button allows to view the List of Job(s) for a range of period based on the date of posting.
To view the List of Job(s) for a period, from the List of Job(s) screen:
The List of Job(s) screen displays the jobs list based on range of period, as shown:
F2: Date
This button allow to view the List of Job(s) for a selected date.
The List of Job(s)s displays the jobs list based on the date specified.
E: Expire Job
The user can expire a published or withdraw jobs based on the business requirements.
To expire  a job, from the List of Job(s) screen:
The Expire Job screen appears, as shown:
Note: Press F12: Configure and set Yes to Show Expire Jobs to view the Expired jobs list.
W: Withdraw Job
The user can withdraw a published jobs based on the business requirements.
To withdraw a job, from the List of Job(s) screen:
The Status of the selected Published job in the List of Job(s) changes to Not Published, as shown:
Shift + Enter: Quick view of Job Details
To view Job details like Job Location and Expiry Date press Shift + Enter with the cursor on the Job name. These details get displayed provided the respective options are enabled in F12 Configurations.
F12: Configure
The List of Job(s) screen can be configured to view the report based on the requirement.
The configuration screen appears as shown:
Match Requirement
This button allows the employer to search for candidates matching to his published jobs.
To match a candidate for a published job follow the steps shown:
In the List of Job(s) screen
The List of Candidate(s) screen appears displaying the list of candidates matching the criteria specified in the selected published job.
The other function keys available in this screen are:
F: Refine Search: Select the required candidate and click C: Consider or press Alt + C
The Consider Candidate screen appears as shown:
The completed Consider Candidate screen appears as shown:
On considering the candidates for the recruitment folder the flag in column Considered (in last 3 months) turns to Yes and the candidates profiles resides in Considered folder of Recruitment.
C: Create Client
The Jobs & Recruitment function not just allows a user to recruit candidates for an employer/user, but it also allows to recruit candidates on behalf of the client.
Refer to the topic separately available on Recruiting on Client's Behalf
L: List of Client(s)
