In order to fix mismatched values of computation, you have to first enable the MRP feature in the stock item master.
To fix the mismatch in values of computation and annexure
1. Enable MRP feature only to print the MRP in invoice .
2. If MRP is enabled for calculation, change the details in XML file to print the MRP .
