Differences Between Synchronization Features Compare to Release 5 and 4.93
This topic explains the differences between synchronization features in Release 5 and 4.93.
Release 5
Till Release 4.93
Not required to connect companies to Tally.Net server, if On-Demand sync is enabled.
Need to connect companies to Tally.Net server through On-line mode.
Both On-line & On-Demand modes of sync available through Tally.Net Server.
Only On-line mode of sync
Provision of syncing Master data without voucher.
Master data need to sync with voucher
No mandatory to connect internet at both the end.
Both server & client company need to be connected to internet to do data sync
It works even if other Tally or system is offline.
Even if Internet is connected, need to ensure Tally application is open
Vouchers can be deleted at any end.
Vouchers should not be deleted
Deleted vouchers will get deleted at other end once after next sync.
Such option is not available
Sync Status & Exception report provided.
Such reports are not available
See also
FAQs on Synchronisation (Release 5)
