Credit Summary displays Opening Balance, Credit for the Month, Utilised and Closing Balance of CENVAT Credit.
To view Credit Summary
Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer > CENVAT Registers > Credit Summary
In the Select Excise Unit screen
Name of Excise Unit : By default Tally.ERP 9 displays ABC Company
If you have more than one manufacturing unit select the appropriate Excise Unit from the List of Excise Units for which you want to view the Credit Summary report.
Tariff No.: Select Plastic Bottles from the List of Tariff No.
Stock item Type: Select Principal Input from the List of Item Types
Stock Item Name: Select All Items from the List of Stock Items
You can select Principal Input or Capital Goods from the Type of Stock items to view the Credit Summary report. Press Alt+F1 or click on F1: Detailed button to view the report in detailed mode.
The Credit Summary appears as shown
