It is a monthly return under Rule 7 of the cenvat credit rules, 2001. This report displays the details of CENVAT credit availed for the Main Item in the Document.
Note: This annexure is omitted (w.e.f 1-10-2003) by M.F. (D.R.) Notification No.70/2003-C.E. (N.T.), dated 15-9-2003. But most of the assessees still submit their monthly returns in Annexure 10. On Customers requirement Annexure 10 is provided in Tally.ERP 9.
To view Annexure 10
Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer > CENVAT Registers > Annexure 10
In Select Excise Unit screen
Name of Excise Unit : By default Tally.ERP 9 displays ABC Company
If you have more than one manufacturing unit select the appropriate Excise Unit from the List of Excise Units for which you want to view the Annexure 10.
Name of Item: Select Principal Input from the Type of Stock Items.
Note: You can select Principal Input or Capital Goods from the Type of Stock items to view Annexure 10.
Annexure 10 is displayed as shown below
Type of Document: Displays the type of document - Excise Purchase invoice/Debit Note through which the credit is availed
No. and Date of Document: Displays the Document No. and Data
Name of the Supplier: Displays the name of the supplier with the information whether the supplier is Manufacturer/First stage Dealer/second Stage Dealer/Importer
C.E.No. of the Supplier: Displays the suppliers Excise Control Code (ECC) number
Date on which principal inputs/Capital Goods received: Displays the date on which the goods are received. In Tally.ERP 9 the Purchase invoice date will be displayed in this field will get captured.
Value: Displays the total value as per document on which Credit is availed
CENVAT: Displays the document wise credit - CENVAT availed amount
Education Cess: Displays the document wise credit - Education Cess availed amount
Secondary Education Cess: Displays the document wise credit - Secondary Education Cess availed amount
For the main item in the document: In this section details like Description , Sub-heading and Quantity details of the main item in the document will be displayed.
Description: In this field Name of the main item in the document will be displayed.
Sub-Heading: Displays the tariff sub-heading of the main item in the document
Qty: Displays the Quantity of the main item in the document
