Synchronisation using Private Network
From Tally.ERP 9 onwards, Direct Client and Direct Server capability for Synchronisation through private network (also referred as IP Sync) is a default feature available in the product. The process for Data Synchronisation remains the same while doing the Sync using Direct – Client and Server capability (or IP Sync).
Steps for Data Sync using IP Sync
The steps for IP Sync are as follows:
