https://help.tallysolutions.com/docs/te9rel55/Data_Management/Import_of_Data_Intro.htm
Importing Data into Tally.ERP 9
You can import data into Tally.ERP 9 in XML format. You can import Masters created in previous versions of Tally.ERP 9 or from third party applications.
The .xml file that is imported must follow the Tally.ERP 9 schema.
Click the following links for more information:
     Importing Masters
     Importing Vouchers
