https://help.tallysolutions.com/docs/te9rel66/Tax_India/excise-mfg/enable-mfg-excise.htm
Enabling as manufacturer of only 2% goods
If your business involves dealing with only goods taxable at 2%, then provision can be made to set this during excise registration.
To configure as a manufacturer of only 2% goods
1. Click F12: Configure from the Excise registration details screen.
2. Enable the option Enable as manufacturer of only 2% goods.
3. P ress Ctrl+A .
4. Enable the option Deals only with 2% goods .
5. Click L : Details to define the date of applicability for dealing with 2% goods.
6. Enter the date in the field Applicable from .
7. Select the Types of Manufacturer .
8. Select Yes in the field Is 2% Goods .
9. Set applicability details for the next period, if required.
10. Press Enter to go to the Excise registration details screen.
