https://help.tallysolutions.com/docs/te9rel66/Banking/view_current_and_final_balance.htm
View Ledger Balances Considering Post Dated Transactions
In the Voucher Creation/Alteration screen, two options are provided in F12: Configure to consider the post-dated transactions while ascertaining the balances of party ledgers.
ā—¸ Show Bill Final balances : Enabling this option will display the amount that remains due, if any post allocation, in the Bill-wise Details screen.
ā—¸ Show Ledger Final Balances : Enabling this option will display the party ledgerā€™s balance after including the post-dated transactions for the party ledger, in the Voucher Creation / Alteration screen.
