Explore Categories
 PDF
Pre-close Job Work Order in TallyPrime
You can pre-close only the job work orders in TallyPrime that were raised wholly.
  1. Gateway of Tally > Display More Reports > Job Work Reports > Orders and press Enter.
    Alternatively, press Alt+G (Go To) > type or select Job Work Order Summary and press Enter.
  2. Select the order that needs to be pre-closed and press Enter.
  3. In the Job Order Details screen, press Alt+W (Close Order) to pre-close the order.
    The Job Order to Close screen appears with the option Close Orders.
  4. Press Enter to confirm pre-closure.
Post a Comment
Helpful?
