Use Connected Banking in TallyPrime
Available from TallyPrime Release 6.0, Connected Banking makes your banking tasks simpler. With Connected Banking, you can get Bank Statements and Bank Balance right from TallyPrime. This saves you a great deal of time that you can utilise for more important tasks of your business.
To get started with Connected Banking, you need the following:
- Active license
- Valid TSS
- Tally.NET ID or a valid e-mail address
- Valid 10-digit mobile number for linking with your Tally.NET ID and receiving OTP
Set Up Connected Banking
As a one-time setup for Connected Banking, you need to do the following:
- Link a mobile number to your Tally.NET ID.
- Change your Tally.NET password, if it does not meet the latest password policy.
- Connect your bank accounts to TallyPrime.
Link mobile number to Tally.NET ID
- Press Alt+Z (Exchange) > All Banking Options > Login & Logout.
- In the Log In to Connected Banking screen, enter your Tally.NET ID.
If you are working with multiple users under a license site, then refer to Approve User Access to Connected Banking for non-admin users.
- Enter your Tally.NET password.
- Enter the mobile number that you want to link to your Tally.NET ID.
- View T&C and Privacy Policy: Yes.
You will get redirected to the web page where you can read the T&C and Privacy Policy and then accept it. - Enter the OTP received on your mobile number.
If you do not receive the OTP, press Alt+R (Resend OTP).
The mobile number gets linked to your Tally.NET ID.
If your password does not meet the new password policy introduced for Connected Banking, then you will need to change the password.
As a result, you get logged in and can use the Connected Banking services.
You can proceed to connect your bank accounts to TallyPrime.
If you want to know how to link mobile number to Tally.NET ID on the Tally Solutions Customer Portal, then click here
Link mobile number to Tally.NET ID on the portal
- Log in to the Tally Solutions Customer Portal.
- Click MY PROFILE.
- Update the mobile number.
- Under Connected Banking Services, click the edit icon.
- Enter the mobile number and click the tick mark icon (✓).
- Check the box to agree with Terms and Conditions & Password Policy.
- Click UPDATE.
- Click OK.
- Enter the 6-digit OTP sent on your mobile number.
- Click SUBMIT.
In case of multiple users under a license site, as an admin, you need to enable Connected Banking for the non-admin users. Once you approve the users using your Tally.NET credentials, they can use the Connected Banking services.
If you are a non-admin, then the approval request goes to the admin. The admin can then approve user access to Connected Banking either in TallyPrime or on the Tally Solutions customer portal.
The Log In to Connected Banking screen appears. - Enter your Tally.NET ID.
If the Tally.NET ID does not exist, is inactive, or the Connected Banking is not enabled for the user, then a message appears.
- Press Y to proceed.
- Press A to Approve as Admin.
- Enter the Tally.NET ID and Password of the Account Administrator or owner for approval.
Once approved, either you or the user can link the mobile number to the Tally.NET ID and change the password, if it does not comply with the new password policy.
If you want to know how to access user access to Connected Banking on the Tally Solutions Customer Portal, then click here
Approve user access to Connected Banking on the portal
When you create a new user in TallyPrime, you can approve the user right in TallyPrime or on the Tally Solutions Customer Portal.
- Click CONTROL CENTRE > User Management > Manage User.
- Under Connected Banking User Status, click 1 Pending on the required user’s row.
- Click the tick mark icon (✓).
- Click OK.
The user gets approved to use the Connected Banking services in TallyPrime.
Create user and approve access to Connected Banking on the portal
You can create a user and approve access to Connected Banking even on the portal. As a result, the user will be able to log in to Connected Banking in TallyPrime.
- Click CONTROL CENTRE > User Management > Manage Users.
- Click CREATE USER.
- Select the Security Level, for example, Standard User.
- Enter the e-mail address of the user.
This will be the Tally.NET ID of the user, and the user will receive a temporary password in the same e-mail address. - Check the Enable Connected Banking Services box.
- Click CREATE.
- Click OK to confirm.
As a result, the user gets created with Connected Banking approval.
Connect Bank Accounts
When you connect to a specific Bank, a Connection ID gets generated. This is the reference ID for the connection initiated with the Bank.
Once the connection is successful, you get a list of account numbers with the matching Bank ledgers.
- Press Alt+Z (Exchange) > All Banking Options > Bank Connections.
If you have not logged in to Connected Banking already, then you will need to log in. - Press F6 (New Connection).
- Select the relevant bank.
If there are connections pending for approval for the bank, then you will get a message.
In that case, you can press Y to proceed.
A connection ID gets generated. - In the Connect to Bank screen, press C (Connect).
Consequently, you get redirected to the respective bank portal.
Refer to Connection with Axis Bank or Connection with Kotak Mahindra Bank to know more.
Once you establish the connection with the bank on the portal, you can refresh the status. - Press R (Refresh Status).
The status of the connection gets displayed in the Bank Connections report as Connected.
Once you establish the connection with the bank, the bank accounts get linked. If there are ledgers matching the bank accounts, then the ledgers also get displayed.
After the one-time setup, you can log in to Connected Banking at any point in time. Thereafter, you can get bank balance and statement using Connected Banking in TallyPrime.
If you are not logged in, then you will need to log in with Tally.NET ID, password, and OTP.
Get Bank Balance
With Connected Banking, you get to know your Bank Balance in a matter of seconds and that too, right from TallyPrime. This helps you decide the account using which you can send payments to your suppliers. You only need to ensure that you are logged in to Connected Banking.
- Press Alt+Z (Exchange) > Get Balance.
Alternatively, press Alt+Z (Exchange) > All Banking Options > Get Balance. - Select one or more bank accounts to get the balance.
- Press B (Get Balance).
If the balance is fetched for multiple bank accounts and the process fails for one or more bank accounts, then an Exchange Summary appears.
You can further configure this report to view Bank Name and Ledger Balance as per Books for comparison with the balance as per bank.
Furthermore, while you get to know the balance of your bank accounts, you can view other balances sent from the bank.
Get Bank Statement
With Connected Banking, you can seamlessly get bank statements. You can then use the bank statements to reconcile the transactions in books.
- Press Alt+Z (Exchange) > All Banking Options > Get Statement.
- Set the period for which you want to get the statement.
- Select the bank ledger and press Alt+S (Set Statement Period).
- Enter the From and To dates and press Enter.
- Press S (Get Statement).
- Import the statement.
You can view the transactions from the imported statements in the Imported Bank Data and Bank Reconciliation reports.
If you are not using Connected Banking services, then you can import bank statements to perform auto reconciliation.
Delete Statement Request
You might want to delete a statement request when it was requested for the wrong period.
- Bring the cursor to the request.
- Press Alt+R (Delete Request).
- Press Y to confirm.
The request gets deleted.
Reset Bank Statement Data
You can reset the bank statement data when:
- You have imported the statement for a wrong period.
- You have already reconciled your transactions. Therefore, you do not want the imported bank statements in your Company data anymore.
- Press F1 (Help) > Troubleshooting.
- Select Reset Bank Statement Data and press Enter.
- In the Reset Bank Statement Data screen, select the Bank Ledger.
- Retain Reconciliation Status: Yes.
The reconciliation status of the fully reconciled transactions gets retained. However, if there are any partially reconciled transactions, then their status becomes Unreconciled.
If you had imported the statement for a wrong period, then set Retain Reconciliation Status as No. - Enter the From and To dates.
The Bank Statement data will get cleared for the specified status. - Take a backup of the Company data, if needed.
The bank statement data gets cleared.
Reconnect/Disconnect Bank and Manage User Access
The facility to manage bank connections allows you to reconnect or disconnect from your bank, whenever needed.
- Select the bank connection, and press Enter or F7 (Manage Connection).
Reconnect Bank Accounts
You can reconnect to the bank using an existing Connection ID in the following scenarios:
- The connection is still in progress.
- The connection has expired when:
- The connection has crossed its validity.
- The mobile number has been changed.
- In the Manage Connection screen, press F6 (Reconnect to Bank).
- In the Reconnect to Bank screen, press C (Connect).
Consequently, you get redirected to the bank portal.
Refer to Reconnect with Axis Bank or Reconnect with Kotak Mahindra Bank to know more.
Disconnect Bank Accounts
Some of your bank accounts might be dormant. So, you might not want to use the bank accounts through Connected Banking. When you do not want to use bank accounts of a specific bank, you can disconnect from the bank.
- In the Manage Connection screen, press Alt+F6 (Disconnect).
- In the Disconnect from Bank screen, press D (Disconnect).
- Press Y to disconnect from the bank.
In case of Axis Bank, you will need to enter the OTP received on the mobile number registered with the Bank.
Manage User Access to Bank Accounts
If there are multiple users in a bank and your bank follows the system of approval, then you will see the list of users in the Manage Connection screen. You will need to approve user access to bank accounts.
However, in the list of users, a user might have the status as User does not exist when:
- The user has not linked the mobile number.
- The user does not have a Tally.NET ID.
Approve User
You can approve access for the users for whom approval is pending.
- In the Bank Connections report, press F7 (Manage Connection).
- Select the user, and press F8 (Approve Access).
The user will be able to access the Connected Banking services.
Disable User Access
If you want to disable bank access for a few users, then you can easily do so.
- Select the user and press Alt+F8 (Disable Access).
The user will not be able to access the Connected Banking services.
Log In/Log Out from Connected Banking
You can log in using your Tally.NET ID and password at any point in time.
Log in to Connected Banking
- Enter your Tally.NET ID in the Log In to Connected Banking screen.
Once you enter the OTP, you get logged in to the Connected Banking services.
Log in when the session is expired or inactive
A Connected Banking session expires after 24 hours. In such a case, you can enter your Tally.NET password and OTP to log in.
Moreover, your Connected Banking session might become inactive in three cases:
- No activity is performed for more than 15 minutes.
- The Company is shut and opened in another instance of TallyPrime.
- TallyPrime is closed.
In case of an inactive connection, you need to enter just your Tally.NET password to log in.
When you are not using any Connected Banking facility, you can log out.
Reset Connected Banking Login
When you are not able to log out of Connected Banking, you can reset the Connected Banking login.
Change Password
You will need to change your password if it does not adhere to the new password policy. Your new Password should either be a 6-10 digit PIN or contain at least 8 characters with one uppercase letter, one lowercase letter, a number, and a special character.
- Enter the Old password.
- Enter the New password.
- Confirm the New password.
- Press Enter.
The password gets changed.
If you want to know how to change your Tally.NET password on the Tally Solutions Customer Portal, then click here
Change password on the portal
- Click MY PROFILE.
- Click Change Password.
- Change your Tally.NET Password.
- Enter the Current Password.
- Enter the New Password.
Your new Password should either be a 6-10 digit PIN or contain at least 8 characters with one uppercase letter, one lowercase letter, a number, and a special character. - Re-enter the New Password.
- Click CHANGE PASSWORD.
- Click OK.
You can also reset your Tally.NET password at any point in time.
