Configure Advanced Options for Groups
You can configure additional group information such as:
● Sub-ledger creation of groups
● Nett debit/credit balances for reporting
● Calculations
● Method to allocate purchase invoice
Advanced configurations
Button options in Group Creation Screen
1. Go to Gateway of Tally > Accounts Info > Groups > Create (Single Group) .
2. Select F12: Configure (Group Configuration) and enable Allow advanced entries in masters.
The group creation screen with advanced options is displayed as shown below:
In the Group Creation screen
1. Enter a name for the group.
2. Enter a group category. If a group is created under Primary you must select from asset, expenses, income or liability.
3. Select the Nature of Group .
4. Select Yes for the option Group behaves like sub-ledger? to allow groups to act as a ledger.
o When the option Group behaves like sub-ledger? is set to Yes , the ledgers grouped under the same is not displayed in detailed mode, as shown below:
o When the option Group behaves like sub-ledger? is set to No , all the ledgers that are grouped is displayed in detailed mode, as shown below:
5. Set Nett Debit/Credit Balances for Reporting? to Yes to display net debit or credit balance in the report (whichever is higher).
6. Set Used for Calculation (e.g. taxes, discounts)? to Yes if ledgers under this group have percentages for discounts or taxes to be used in invoice entry. This is displayed while passing voucher in invoice mode and for automatic calculations.
7. Select Method to Allocate when used in Purchase Invoice from the Allocation Methods list to allocate the expense of the item in the ratio of the quantity or value.
Button
Shortcut Keys
Behaviour
L: Ledgers
Ctrl+L
Click to view Ledger Creation screen
S: Cost Category
Ctrl+S
Navigate to Cost Category Creation screen
C: Cost Center
Ctrl+C
Navigate to Cost Centre Creation screen
O: Employee Groups
Ctrl+O
Navigate to Employee Groups Creation screen
E: Pay Heads
Ctrl+E
Navigate to Pay Head Creation screen
P: Employee
Ctrl+P
Navigate to Employee Creation screen
T: Attd Type
Ctrl+T
Navigate to Attendance/Production Type Creation screen
U: Units
Ctrl+U
Navigate to Unit Creation screen
B: Budget
Ctrl+B
Navigate to Budget Creation screen
V: Vch Types
Ctrl+V
Navigate to Voucher Type Creation screen
The default buttons available are L: Ledgers and V: Vch Types . The other options are displayed based on the accounting features enabled in F11: Features .
Note: F12: Configure changes apply to all companies while changes made in F11: Features affect only the current company.
