Jobs & Recruitment is a built-in feature designed to recruit candidates by following the recruitment procedure.
Using Jobs & Recruitment , you can:
● Search for manpower with pre-defined skill sets.
● Conduct knowledge assessment on topics widely used by the business.
● Enroll candidates into the main stream business.
● Conduct recruitment process and accommodate job applications received through any media such as e-mail, walk in candidates and references.
Some of the key functionalities offered by jobs and recruitment are:
Functionality |
Use |
Recruitment |
Recruit clients and also use recruit only feature |
Publishing jobs |
Publish job requirements based on the positions vacant |
Search and save |
Search for appropriate candidates and save the search for future use |
Match and access |
Match candidates for a job an asses existing employee's knowledge |
Track recruitment |
Track candidate during the recruitment process |
To use Jobs & Recruitments
1. Select Jobs & Recruitments .
2. Press Enter . The Control Centre screen appears as shown below:
