Tally Software Services (TSS) is a set of capabilities that helps you add value to Tally.ERP 9. With TSS, additional capabilities such as continuous improvements to the product, central consolidation of all branch office data over secure servers, remote connectivity, banking services, instant support from within Tally.ERP 9, and many more features that enhance business performance are available.
You need to enable the option Use security control in the Company Creation screen to configure and use the TSS features.
To enable the security control feature
1. Press F3 : Cmp Info in the Gateway of Tally screen.
2. Enable the option Use security control .
3. Press Ctrl+A to save.
1. Go to Gateway of Tally > F11: Company Features > F4: TSS Features . The Company Operations Alteration screen appears.
2. Enter the Connection Details .
Note: The connect name entered here must be entered during client rule creation.
3. Enter the Configuration for Remote Access details.
4. Enter the SMS access details.
Note: The company name in the SMS Company Name field should not exceed 8 characters.
5. Press Enter to save.
