The cursor skips the Tally.ERP 9 is acting as field, in the Advanced Configuration screen, if the option Can be overridden locally? is set to No in the General Configuration Management screen of the Control Centre .
The Advanced Configuration screen with the cursor skipping the field Tally.ERP 9 is acting as appears as shown below:
To resolve this issue,
1. Press Ctrl+K to login to Control Centre .
2. Login by providing your Tally.NET username and password.
3. Select License Management .
4. Press F9: General Config .
5. Select Default General Config from the list.
6. Enable the option Can be overridden locally? as shown below:
7. Press Ctrl+A to accept.
On enabling the option Can be overridden locally? in the General Configuration Management screen, the field Tally.ERP 9 is acting as in the Advanced Configuration screen is enabled.
