Manage Data Sessions
The Manage Data Sessions screen displays important information about remote login data sessions (login by various users into the administrator's remote companies) of  authorised users.
This screen displays the Name or IP Address of the computer using which the user had logged in, the Start Time for each session, the time when the Last Activity took place along and the Status of an individual session for the respective User ID which is displayed against the Tally.NET ID field.
View the Manage Data Sessions screen
Button options in Manage Data Sessions screen
1. Go to the Control Centre.
2. Select N : Manage Data Sessions .
3. Press Enter . The Manage Data Sessions screen appears:
● F3: Tally.NET ID-wise : Press F3 to configure the information based on Tally.NET IDs of the users.
● F5: Refresh : The button can be used to update My Sessions screen with latest log in.
● F12: Configuration : The following options can be used to configure Manage Data Sessions screen:
o Status: The Status of the user - Active or Idle
o Tally.NET ID : The report can be viewed for a particular Tally.NET ID.
o Group By: This option servers the same purpose as F3: Tally.NET ID wise - the report will display information by categorising them based on the Tally.NET IDs.
● D : Delete Session : Place the cursor on the required session. Click D : Delete Session or press Alt+D to delete the session.
