How is the Outwards consumption value calculated for inter- godown transfers at stock item level from Release 5.5.5?
Consider the following scenario
· The opening balances for the stock item Aluminum Foil in 3 godowns of a company are as below
Location
Quantity
Rate per unit
HSR
100
30
Hosur
50
29
Electronic City
50
32
● A purchase is made for 50 numbers of the stock item in Electronic City godown
● A transfer of 20 sto ck items is made from Electronic City godown to Hosur godown.
The Outwards consumption is calculated as 20(No of stock item) * 32(The rate of the stock item in the concerned godown).
From Release 5.5.5, the Outward Consumption at godown level and item level will be the same as shown below:
At Item level:
At Godown level:
