You can modify a budget using the alter option.
To alter a budget
1. Go to Gateway of Tally > Accounts Info > Budgets > Alter.
2. Modify the fields as required, i n the Budget Alteration screen.
3. Change the period or change budgets of Groups , Ledgers , and Cost Centres .
Note: By default, Set/Alter Budgets is set to No . Set this option to Yes to alter .
To delete a budget
1. Go to Gateway of Tally > Accounts Info > Budgets > Alter .
2. Press Alt+D to delete.
