Configuring a Group for Custom Duty (Excise for Importer)
You can create a separate group with a name like 'Import Duties’ under Indirect Expenses for custom duty.
To create a custom duty group
1.    Go to Gateway of Tally > Accounts Info. > Groups > Create.
2.    Enter the Name for the group.
3.    Select Indirect Expenses in the field Under.
4.    Provide other details, as required.
5.    Set the option Set/alter excise details? to No. The completed screen appears as shown below:
6.    Press Enter to save.
