Consider the following scenario
· The opening balances for the stock item Aluminum Foil in 3 godowns of a company are as below
Location |
Quantity |
Rate per unit |
HSR |
100 |
30 |
Hosur |
50 |
29 |
Electronic City |
50 |
32 |
● A purchase is made for 50 numbers of the stock item in Electronic City godown
● A transfer of 20 stock items is made from Electronic City godown to Hosur godown.
The Outwards consumption is calculated as 20(No of stock item) * 32(The rate of the stock item in the concerned godown).
From Release 5.5.5, the Outward Consumption at godown level and item level will be the same as shown below:
At Item level:
At Godown level:
