Increase in Input Tax
To capture increase in input tax, you can create a journal voucher with Increasing Input Tax as the nature of adjustment.
To create journal voucher for tax credit on opening stock
2.    Click J: Stat Adjustment. In the Stat Adjustment Details screen,
o     Select the option VAT in the Type of duty/tax field.
o     Select the option Increasing Input Tax in the Nature of adjustment field.
o     Press Enter to save and return to voucher screen.
3.    Debit the input VAT ledger.
o     Enter the Rate, Assessable Value and Schedule Serial No., and select the Schedule Name in the VAT Details screen.
5.    Credit the purchase ledger.
o     Select the Name of Item and enter the Amount in the Inventory Allocations screen.
6.    Press Enter to save.
