Job Work in Tally.ERP 9
Tally.ERP 9’s simple yet powerful Job Work feature enables you to record transactions related to Job Work with ease. The Job work functionality in Tally.ERP 9 has the following features:
     Simple and user-friendly
     Quick and easy to set up and use
     Job Work Out Process
o     Record Job Work Out Order by capturing the details of Components to be issued and Finished Goods /Scrap to be issued
o     Account the Receipt of Components towards a Job order or directly record the Material receipt by creating the Job Order.
o     Flexibility to account the Receipt of Finished goods without raising Job Work Out Order and Material In voucher
o     Track cost against the Job Work Out Orders
     Job Work In Process
o     Record Job Work In Order by capturing the details of Components to be received and Finished Goods /Scrap to be delivered
o     Flexibility to account the delivery of Finished goods without raising Job Work Out Order and Material In voucher
o     Track the Own Consumption of Goods against the Job Orders and Bill the same on the Principal manufacturer
     Generate Annexure II for Removal of Goods for Job Work
     Maintain and Generate Annexure IV (by Principal Manufacturer - if excise applicable)
     Maintain & generate Annexure V (By Job Worker - if excise applicable)
     Reports
o     Generate Order Outstandings report for Orders & Components
o     Generate Job Work Registers such as Job Work Out Order/Job Work In Order
o     Material Out Registers
o     Material In Registers
     Material movement Register
o     Provision to view the details of Stock lying with the Job worker and ageing of the stock
o     Provision to generate the report to analyse the variance in issue of components and receipt of finished goods and vice versa.
