Jobs & Recruitment is a built-in feature designed to recruit candidates by following the recruitment procedure.
Using Jobs & Recruitment, you can:
● Search for manpower with pre-defined skill sets.
● Conduct knowledge assessment on topics widely used by the business.
● Enroll candidates into the main stream business.
● Conduct recruitment process and accommodate job applications received through any media such as e-mail, walk in candidates and references.
Some of the key functionalities offered by jobs and recruitment are:
Functionality  |
		Use  |
Recruitment  |
		Recruit clients and also use recruit only feature  |
Publishing jobs  |
		Publish job requirements based on the positions vacant  |
Search and save  |
		Search for appropriate candidates and save the search for future use  |
Match and access  |
		Match candidates for a job an asses existing employee's knowledge  |
Track recruitment  |
		Track candidate during the recruitment process  |
To perform any functions in Jobs & Recruitment section
1. Select Jobs & Recruitments.
2. Press Enter
The Control Centre screen appears as shown below:
