Comparing Jobs or Projects
The Job Work Analysis report displays details of multiple jobs  in a single report. The details are viewed in different columns for comparison.
To view multiple Job/projects
1.    Go to Gateway of Tally > Display > Statement of Inventory > Job Work Analysis.
2.    Click N:Auto Column.
3.    Select the parameters, as required.
The Comparative Job Work Analysis report appears as shown:
Viewing another project for comparison
To view another project for comparison
1.    Click A: Alter Column. The Select Columns screen appears as shown below:
2.    Select the Job/Project to be compared in the field Name of Cost Centre.
Job Work Analysis report appears as shown below:
3.    Press F4 to select another Job/Project.
4.    Select the Job/Project.
5.    Press Enter to go to the Job Work Analysis report.
Note: You can drill down to the voucher level to view the break up of the job/project.
