Job Work (Out) Location
You can create this godown to account the goods lying with the Job Workers (third party).
To create the Job Work (Out) Godown
1.    Go to Gateway of Tally > Inventory Info. > Godowns > Create.
2.    Enter Name of the godown.
3.    Select Primary in the field Under.
4.    Set the option Our stock with third party? to Yes.
The completed screen appears as shown below:
Note: On enabling the Our stock with third party?, cursor will not move to next field. Hence a godown can be configured to use the godown for any one purpose.
5.    Press Enter to save.
