E-mailing using External (User-defined) Servers
You can e-mail reports, invoices, purchase orders, reminder letters, and so on, using an external server, as defined by the user.
To e-mail a ledger using a user-defined e-mail server
1.    Go to Gateway of Tally > Display > Accounts Books > Ledger.
2.    Select the required ledger account from the List of Ledgers.
3.    Click M: E-Mail on the Ledger Vouchers screen to open the E-Mail Report screen.
4.    Press Backspace on the Mailing Ledger screen to modify the parameters.
o     Select User defined from the list of Common Mail Servers in the E-Mail Server field.
o     Enter the name of the external server in the Server Address field.
o     Enable Use SSL and Use SSL on Standard Port, if required.
o     Modify From and From E-Mail Address, if required.
o     Enter Authentication User Name and Password, if required.
o     Select the required Format.
o     Select the required Page Size.
o     Select the required Page Orientation.
o     Enter the e-mail address of the intended recipient in the To E-Mail Address field.
o     Enter another e-mail address in the CC To (if any) field, if you want to send a copy of the same e-mail to more than one recipients.
o     Modify the Subject, as required.
o     Enter Additional Text (if any), if required. This will precede the report in the recipient’s mail program.
o     Select the format in which the Information Sent can be viewed.
o     Set additional mailing configurations, as required.
5.    Press Enter to e-mail the ledger.
See Also
E-mailing Reports
E-mailing reports in PDF format
Mass Mailing
